Inventor General
Valued Mentor
rhasell
Message 11 of 13 (211 Views)
Re: Edit Extrusion, OK button Greyed out
10-17-2012 04:11 PM in reply to: Yijiang.Cai
Thank you
This issue is not high on my priority list, it was just something that crops up every now and again, and I was hoping that someone else had experienced it, and possibly had a solution or an explanation as to why it happens.
If I could understand why it happens, I will try to avoid it while designing, probably something silly that I am doing with the workflow, esp considering that I had to modify the part a few times, and added cuts out of order.
Thanks once again.
Reg
Autodesk Product Design Suite Premium 2014 SP1-Update 2 Build 222
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please accept as a solution if it fixes your problem.
Employee
Message 12 of 13 (189 Views)
10-31-2012 01:52 AM in reply to: rhasell
Hi Reg,
We take much investigation on this behavior, and it is a known issue for us. When looking into the extrusion, you will find that the key factor is that the symmetric flip direction is used for extrusion cut. For this issue, the reason why is pretty simple. Edit the extrude feature and change extent from All to Distance, you will see the distance value is set to zero, which is illegitimate. As a result, the dialog does not like the condition and then greys out the OK button. To fix the issue, you could have two choices.
Choice A: When switching extents type from Distance to All, simply give a meaningful value like 1mm or 1in (default value), instead of zero.
Choice B: Do not check for Distance value when extents type is set to All.
Generally Choice A would be a better solution and easier to implement, since any value Inventor sets should be meaningful.
River Cai
Inventor Quality Assurance Team
Valued Mentor
rhasell
Message 13 of 13 (171 Views)
10-31-2012 04:02 PM in reply to: Yijiang.Cai
Thank you for taking the time to debug the error.
I thought I was going mad, as it was quite difficult to re-produce the fault in another model, so I guess it was something in my workflow.
I am happy with the solution, at least I know what to do if it goes pear shaped again.
Reg
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
