Inventor Forum
Edit Dimensions in Inventor 2012
2 REPLIES 2
1170 Views, 2 Replies
Hi, i am having a problem when I try to edit a dimension in my Idw's. I normally can double click on the dimension or right click on it and choose edit, but now the window will not pop up. It freezes the screen like the window is open but no window on the screen, almost like it opens off of the screen where you can not see it, the program has been reinstalled but still have the same problem. . . . any suggestions?
2 REPLIES 2
ampster402
have you tried the alt+spacebar trick to move the window?
press alt and the spacebar at the same time
then press m (for move)
then use your arrow keys to move the window (an alt way to complete this step is to use your mouse at this point)
Note, you should try this with a visible window first to see how it works, then when you are trying to reorient the window so it's visible, you may have to try this a few times in order to determine where the window actually is.  Using the mouse instead of your arrow keys may be quicker in determining where the window is.
HTH
That was it thanks!
