The drop down arrow and check mark have disappeared from my Edit Dimension Dialog Box. Can anyone direct me to the setting to turn those back on?
Can you be more specific as to what environment you are in, and maybe post a screen shot?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
When in the sketch environment, modifying/editing a dimension. You can see in the attachment, the edit box only has the dimension. There is no check mark to click for "ok" nor is there the drop down arrow with the last few dimensions.
Wow. Inventor 11. I haven't seen that in a few years.
Was the other functionality always there, and then suddenly changed? Or has this always looked this way? What, if anything, did you change as far as settings recently?
Chris Benner
Yeah, I know!! LOL I don't use it often enough to justify new software, or so they think...
Those functions have always been there before now. I just noticed it one day last week being gone. I have not changed any settings to the best of my knowledge. The only thing is, they replaced my monitor last week. I adjusted the background colors a little bit. It was shortly after that, I noticed the features not being there. I don't see how that would effect this though?
Hi! What release of Inventor are you running? Have you installed the latest Inventor updates? Are all critical Windows updates installed too?
Many thanks!
HI
I am using inventor 13 on windows 10. I have a lot of issues because windows 10 doesn't support inventor 13. I have all the updates. My edit dimension box had the check mark and drop down menu for about a year with windows 10. I have 3 monitors set up and changed one out then back again and the check mark and drop down menu is now gone. I assumed there may be a setting for this but cannot find it.
