Inventor Forum
Eco Materials Advisor, will not connect!
7 REPLIES 7
Message 1 of 8
SteveJoynson9171
1427 Views, 7 Replies
Cannot connect to the gateway of the eco materials advisor. contacted granta they told me it may be my company firewall, spoke to my ID dept and they tell me its not firewalled.  Tried to download upgrade package with hope that will solve problem, will not download due an existing file on my pc, cant find that one either!
HELP!
7 REPLIES 7
Message 2 of 8
blair
in reply to: SteveJoynson9171
Just download the 64 bit update a couple of minutes ago without any problems.
Delta Tau Chi ΔΤΧ
Message 3 of 8
SteveJoynson9171
in reply to: blair
Finally managed to download the update, but still will NOT connect in inventor!
Message 4 of 8
Hi
In Eco Materials Adviser Settings, could you please chack if the Connection Settings are filled.
Then check with your IT Department if you are using a Proxy Connection and then fill in the Proxy Setting correctly.
Is it working better ?
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
Message 5 of 8
the connection settings are filled in and i cannot edit them, the proxy settings i can input but i have spoke to my IT dept and they tried our proxy settings with no success (see pics attached)
Message 6 of 8
Hi Steve,
I contacted Granta support to ask them to follow up with you but I'm not sure that they have your contact information (the name they had was different than yours).   Would you please send me e-mail at alison<DOT>davis<AT>autodesk<DOT>com?
Alison
Message 7 of 8
pierre.masson
in reply to: AlisonDavis
If you are using a proxy, then I would advise you to try these steps with IT Department :
1)      Use the EMA settings page to enter proxy credentials and then Save these to the EMA configuration file
2)      Close Inventor
3)      Open the EMA configuration file in a text editor. The location of the file will be installation and OS specific. For me it can be found at: C:\Users\nic.austin\AppData\Local\GrantaGateway\config\GatewayConfig.xml
4)      In the <config:ProxySettings> tag, enter the proxy address and port number in the appropriate elements
5)      In the <config:Service> tag, set the useProxy attribute to “true”
6)      Save the config file
7)      Restart Inventor
Please mark it as solution if this solves your issue.
Message 8 of 8
AlisonDavis
in reply to: pierre.masson
Hi everybody,
I spoke to Granta support directly and they have resolved the original poster's issue.  Although the solution involved editing a configuration file they do not recommend that procedure without guidance.   If you have issues connecting to the EMA server, please contact Granta support.  There is a link on the EMA help page to contact Granta or visit http://www.grantadesign.com/contact/.
Alison Davis
