Solved by Jon.Dean. Go to Solution.
Solved by jeffrey.sun. Go to Solution.
I had another customer with a similar problem and I logged the issue with development.
I am still waiting for them to update me.
I think the problem is the Add-in ID but I am not 100% sure.
Hi Rthapa,
Your iLogic code works. I tried the following steps.
Result: The dwg can be generated correctly.
Can you verify if the ini file ("C:\temp\DWGout.ini" ) referenced in your code exist? Expection will be thrown if it doesn't exist.
If the problem still exists on your build, could you upload a problematic idw with the rule and the screenshot for the error message? It will help a lot to triage the issue.
You have created this thread twice now.
Please add your comments to the original forum request.
Jon.
Hi Jeffrey.Sun,
You are awesome. Your suggestion worked.
My original IDW template was migrated from Inventor 2011 to Inventor 2012 with the rules already embeded.
With your suggestion, I created a new blank IDW template with no rules then added the same old rule in it. It works like a charm now.
Somehow migrating old template was failing.
Yeh! Off to the races.
Raj
