hello inventor gurus
i export inventor 2013 files as STEP files,
but instead of STEP files i get
3DSMAXDESIGN BI-PED STEP files.
when i open these 3DSMAXDESIGN BI-PED
STEP files in inventor the 3d models are not
there ???
any clues would assist.
pumpmanplee
Make a 1mx1mx1m cube.
Save as stp.
Attach the ipt and stp files here.
Hi PUMPMANPLEE,
Thanks for your report !
I suppose you use Inventor 2013 to create model and then export it to STEP format and from your description it seems nothing is imported. I need to check if your exported STEP file is good or corrupt if you can post your files here as JD's suggestion or directly contact me via Hongyuan.Li@autodesk.com .
Kevin Li
Quality Assurance Team
Autodesk, Inc.
