I'm designing a hinged cover for something right now that will use a pair of gas extension springs for assisted opening. I'm currently working to figure out how much force it will take to open the cover using different values of spring - it's available in 50, 100, 150, 200, etc., lb versions.
I've tried running simulations using a force applied to the moving end of the gas spring, and I've trued running simulations using a spring joint applied between the fixed and and the moving end of the gas spring, and I'm getting dramatically different results between the two. For instance, using a 200 lb force shows me that I need about 25 extra lbs of force applied to the handle of the cover to open it, where when I use that same 200 lbs on a spring joint, I need 50-75 lbs to keep the cover closed, because it will open on its own.
Which is the correct direction to go here?
Rusty
Solved by JDMather. Go to Solution.
I will take their lab reports and write up a condensed report when I get a chance and attach here.
It is interesting enough that I will add this one to my book (if I ever get around to writing it).
JD -
Have you had a chance to review the student solutions any further? I'm still interested in hearing about what you found so interesting on this one ...
Rusty
Hello
Help yourself with a gas spring positioning software!
Vérinplus 3.10 pros available now on
verinplus.byethost7.com/index.php
VérinPlus is a software for positioning gas or spring jacks.
Designed specifically for design offices, it calculates fixing points and
the effort required to maintain the door, while ensuring that deadlines are met.
