Inventor General
Active Member
jd.gomez242
Message 1 of 6 (424 Views)
Dynamic Simulation Automatization in API
424 Views, 5 Replies
04-10-2012 08:37 AM
Hello, I'm designing multiple elements for a vehicle. I need to evaluate multiple dynamic results of multiple possible designs. All the design is parametric so it modifies quickly but I can't find a way to run the dynamic simulation multiple times automatically and get the results from the output grapher for each simulation.
I am trying to do it via API but can't find the class of the dynamic simulation environment in the Object Model Chart to program it via .NET.
Any ideas would be appreciated
Employee
henderh
Message 2 of 6 (415 Views)
Re: Dynamic Simulation Automatization in API
04-10-2012 10:24 AM in reply to: jd.gomez242
Hi jd.gomez242,
SimulationManager is under ComponentDefinition.
Thanks to Bob van Der Donk, here is a sample VBA that can get you started to run a simulation:
Sub playanimation()
Dim odoc As AssemblyDocument
Set odoc = ThisApplication.ActiveDocument
Dim dsman As SimulationManager
Set dsman = odoc.ComponentDefinition.SimulationManager
Dim dssim As DynamicSimulation
Set dssim = dsman.DynamicSimulations.Item(1)
‘Run the simulation from construction mode without activating Simulation Player!
If Not (dssim.IsInSimulationMode) Then
dssim.ComputeSimulation
End Sub
Hope this helps! -Hugh
Hugh Henderson
Simulation QA Engineer
DLS
Active Member
jd.gomez242
Message 3 of 6 (399 Views)
04-10-2012 02:45 PM in reply to: henderh
Thanks for the quick response. But I can't find the SimulationManager type.
reports: Compile error: User-defined type not defined
Where can I import it from? I'm using Inventor 2012, don't know if there I'm missing a library or something.
Juan Diego Gómez
Employee
henderh
Message 4 of 6 (390 Views)
04-10-2012 04:18 PM in reply to: jd.gomez242
Ahhh...apologies Juan.  The DS API is new to R2013.
Hugh Henderson
DLS
Active Member
jd.gomez242
Message 5 of 6 (380 Views)
04-10-2012 08:30 PM in reply to: henderh
So there is no DS API in R2012... but is there any other way to automatize the Dynamic Simulation?
Juan Diego Gómez
ADN Support Specialist
philippe.leefsma
Message 6 of 6 (180 Views)
07-12-2013 12:27 AM in reply to: jd.gomez242
Hi Juan Diego,
Well if there is no API there is no other way to automatize it, you need to upgrade version, sorry for the bad news.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
