When creating a general table that includes model parameters ie lengths widths etc. is it possible to get the table to apply dual units? For example have it display mm [in] like 50,8mm as 50,8 [2.0] as in the drawing? We are making alot of iparts and this would save us time rather than entering the extra units manually.
You could duplicate the column and set different units on the duplicated column or you could run attached macro that I have put together.
Before you run the macro, select a table first and make sure to change the headertext string "Column 4" to whatever the column you want to treat is called.
Sub dual_units_table() Dim altprecision As Integer altprecision = 3 Dim headertext As String headertext = "Column 4" Dim odoc As DrawingDocument Set odoc = ThisApplication.ActiveDocument Dim ohtable As CustomTable 'Get the UNits of measure Dim uom As UnitsOfMeasure Set uom = odoc.UnitsOfMeasure 'get the default units as defined in teh standard Dim ounits As UnitsTypeEnum ounits = odoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle.LinearUnits 'get the default alternate units Dim oaltunits As UnitsTypeEnum oaltunits = odoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle.AlternateLinearUnits Dim sAltLengthUnit As String sAltLengthUnit = uom.GetStringFromType(oaltunits) 'Select a bend table first On Error Resume Next If Not TypeOf odoc.SelectSet.Item(1) Is CustomTable Then MsgBox "A table must be selected first." Exit Sub Else Set ohtable = odoc.SelectSet.Item(1) End If Dim column As column Dim index As Integer Dim i As Integer index = 0 i = 1 For Each column In ohtable.Columns If column.Title = headertext Then index = i Exit For Else i = i + 1 End If Next column If index > 0 Then Dim row As row For Each row In ohtable.Rows Dim pos As Integer pos = InStr(row.Item(index).value, "[") If pos > 0 Then row.Item(index).value = Left(row.Item(index).value, pos - 1) Dim value As Double value = uom.GetValueFromExpression(row.Item(index).value, ounits) Dim altvalue As Double altvalue = Int(uom.ConvertUnits(value, kCentimeterLengthUnits, oaltunits) * 10 ^ altprecision) / 10 ^ altprecision row.Item(index).value = row.Item(index).value + "[" + Str(altvalue) + " " + sAltLengthUnit + "]" Next row End If ohtable.Update End Sub
Cheers
bob
