Hi Everyone.
I have set up a drop down menu in a iLogic form which promts the user to select an option:
How can I add text to the options so it could be displayed like "UC 100x100x10" rather then just "100"?
This is my code at the moment:
MultiValue.SetList("UC", 100, 150, 200, 250)
iLogicVb.RunRule("Rule27")
Sandy
Solved by shmartin89. Go to Solution.
You need to go into the fx find the UC right click select edit multi value at the bottom dbl click names and change..
Only issue you may have is if it is a Numeric parameter if it is you will not be able to add the "X"
You would have to change it to a text parameter..
I changed my code to this and it displays the options with text......
MultiValue.SetList("UC", "UC152x152x23", "UC152x152x30")
I thought i had already tried it but seems to work now!
Thanks Anyway
Oh so the list is just in ilogic not a parameter my bad...
I do most of my list with a parameter rather then code both ok to use...
Glad it works now for you...
