Hey,
I have recently modelled an assembly that i had constrained sucessfully for animation and functional purposes. I then decided to convert to weldment inorder to include details of the weld beads between the box section assembly.
Firstly, when i drive the constraints the weld bead stays static whilst the rest of the assembly drive constraints work the same as in the assembly environment, is there a way to ensure that the weld bead serves it practical function and moves with the mated box section?
Secondly as the whole assembly consisted of 3 identical sub-assemblies i simply used the pattern component dialog to copy my primary constrained sub assembly so that each would function simultaneously. The problem being that when i done my prep and weld beads on the primary sub assembly it did not copy across with my pattern dialog. I tryed deleting the pattern dialog and re-doing it in weldment environment but still no change. Do i have to perform the same on the other two sub assemblies or is there a quicker way?
Bit of a story book there to explain two problems so hopefully no one is in sleep mode to tackle this question..... 🙂
