Inventor General
karthur1
Message 11 of 16 (321 Views)
Re: Drawings Stamp with Date
04-18-2012 10:27 AM in reply to: bobvdd
I tried it in both 2012 and 2013 last night and got the same error msg in both.  The error that I usually see when its a version issue is "Error reading RSe stream".... or something like that.
I'll try the new file when I get to a machine with 2012. Thanks
karthur1
Message 12 of 16 (303 Views)
04-19-2012 04:01 PM in reply to: bobvdd
Bob,
Just tried to open both of your files using Inventor 2013.  Both of them give me the same error as I posted above...."The doc file has been corrupted".
Product Support
bobvdd
Message 13 of 16 (302 Views)
04-19-2012 04:05 PM in reply to: karthur1
This is really bizarre. I tried with a colleague here at work and he can perfectly open the 2013 file in 2013 without any error.
Bob
karthur1
Message 14 of 16 (287 Views)
04-20-2012 08:27 AM in reply to: bobvdd
I deal with "bizarre" on a daily basis... lol
JamieVJohnson2
Message 15 of 16 (247 Views)
01-07-2013 05:09 PM in reply to: karthur1
CAD Managers,
I took some time to work this out for Inventor 2013.  Here are the results:
Create a custom property or two for your plot stamp in iProperties of the .idw.
ex:
CurrentUser (as text)
PlotDate&Time (as date)
Edit Border Resource and add a text where you want the 'plot stamp', be sure to constrain it to your border lines so it moves with your document sizes.
ex:
<FILENAME AND PATH>, <CurrentUser>. <PlotDate&Time>
<FILENAME AND PATH> exists already and can be found at
  • Type = "Properties - Drawing"
  • Property = "FILENAME AND PATH"
  • Press the Add Text Parameter button to the right.
The other two will be found under Type = "Custom Properties - Drawing"
Create iLogic Rule at Manage\iLogig\Add Rule
ex.
Name = "PlotStamp"
Selecting from the System functions, expand the iProperties section, then select Custom once for each property you want to set.
code:
iProperties.Value("Custom", "PlotDate&Time")= Now & " " & Time
iProperties.Value("Custom", "CurrentUser")=System.Security.Principal.WindowsIdentity.GetCurrent.Name
 Attach your rule to an event such as before save:
at Manage\iLogig\Event Triggers
Select the "Before Save Document" event, then press the Select Rules... button below, then select "Plot Stamp" rule.
Result:
"C\VaultWorkingFolder\TTS CAD\Inventor\Templates\04 DWG TTS.idw, Domain\jvjohnson, 1/7/2013 6:51:24 PM"
Save with your templates and use whenever you create a new Inventor drawing document.
 Perhaps someday, there be an event for 'Before Print' we can hook this into.
Later,
jvj
jvj
karthur1
Message 16 of 16 (225 Views)
01-08-2013 05:25 AM in reply to: JamieVJohnson2
Later,
jvj
What you really have is a "Last Saved Date", not plot date.  They just happen to be the same with this code.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
