Inventor Forum
Drawing styles tutorial - problem
3 REPLIES 3
sandyscott
1198 Views, 3 Replies
I'm new to Inventor, and working my way through the various tutorials, and I'm having trouble with the drawing styles tutorial.
The last bit of the "Object Defaults and Standards" section says "The dimensions in the drawing update to use the period decimal marker" - They don't.
New dimensions are created with the correct style, but existing ones don't update automatically - I can replace them manually with Annotate > Format > Select Style, or by replacing the Default Dimension style with the modified one in the Style Editor.
Is there a step missing from the tutorial, or am I doing something wrong?
Sandy
3 REPLIES 3
Dennis_Jeffrey
in reply to: sandyscott
That's because you created a new object standard. the older dimensions still have the "old" default standard applied.
Ctrl-Pick the "old" dimensions and select a new Dimension standard, OR modify the default standard.
From the Tutorial:
Click Save. Expand the Standard node, select Default Standard (ISO), and create a standard named Modified Standard (ISO).
On the Available Styles tab, select Dimension Modified (ISO) style.
On the Object Defaults tab, set Active Object Defaults to Modified Object Defaults (ISO). Click Save, and double-click Modified Standard (ISO).
The standard name changes to bold type to indicate it is active.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Dennis_Jeffrey
I'd seriously consider taking a class on Inventor so that you can be productive more quickly.
sandyscott
in reply to: Dennis_Jeffrey
I understand how I can create and edit dimension styles, and make them available in a drawing standard, then I can change the style that a particular dimension is using.
Here's what's confusing me:
I've created a new standard that uses the "modified" dimension style, and activated the standard
On a new dimension
I click on the Select Style drop down
The list shows all the dimension styles I've chosen to make available, which is a property of the new standard
However, the top item shows "By Standard (Modified)",  which implies that the dimension is still using the new standard
On an existing dimension
I click on the Select Style drop down (with an existing dimension selected)
However, the top item shows "By Standard (Default)",  which implies that the dimension is still using the old standard
I'm not sure why existing dimensions behave like this, can you force the whole drawing to update and use the new standard?
