Inventor General
Member
focon
Message 1 of 6 (200 Views)
Accepted Solution
Drawing error
200 Views, 5 Replies
09-24-2013 02:49 AM
Hi.
On several occasions i have encountered this dimension error. the only way i have yet found to solve this is by using Ordinate Set dimensioning. It is, as if, inventor is taking they dimensions from somewhere random on the model?
*Expert Elite*
Cadmanto
Message 2 of 6 (171 Views)
Re: Drawing error
09-24-2013 05:50 AM in reply to: focon
What version are you running?
What dimension does your model show?  Have you tried importing the dimension from your model?
Are the dimensions you are showing in your image created in the drawing?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Valued Mentor
mpatchus
Message 3 of 6 (167 Views)
Re: Drawing error
09-24-2013 05:52 AM in reply to: focon
Could it be that one is a "PROJECTED" dimensions and the other a "TRUE" dimension?
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Member
focon
Message 4 of 6 (124 Views)
Re: Drawing error
09-26-2013 03:55 AM in reply to: focon
thank you for your advices and comment. Importing the dimensions didnt work.
but i was now determined to solve this, and did it! If, for some reason, the model has not been grounded or constraint to a plane of origin (XYZ), the dimensions on the drawing will come out as random.
*Expert Elite*
Cadmanto
Message 5 of 6 (108 Views)
Re: Drawing error
09-26-2013 05:42 AM in reply to: focon
No problem.
Advice for the future, I always make sure that my sketches are fully constrained for various reasons.
This be one of them!!!  If they are not constrained then one never knows what effects it will have on a model.
Something so simple can cause major headaches such as this.
Glad you figured it out.
Best Regards,
Scott McFadden
*Expert Elite*
Message 6 of 6 (92 Views)
Re: Drawing error
09-26-2013 08:20 AM in reply to: focon
focon wrote:
... the model has not been grounded or constraint to a plane of origin (XYZ), the dimensions on the drawing will come out as random.
It is not random.  It is Projected rather than True.
When you place or edit the dimension right click and select True.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
