Inventor Forum
Drawing error
5 REPLIES 5
focon
434 Views, 5 Replies
Drawing error
Hi.
On several occasions i have encountered this dimension error. the only way i have yet found to solve this is by using Ordinate Set dimensioning. It is, as if, inventor is taking they dimensions from somewhere random on the model?
5 REPLIES 5
Cadmanto
in reply to: focon
What version are you running?
What dimension does your model show?  Have you tried importing the dimension from your model?
Are the dimensions you are showing in your image created in the drawing?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mpatchus
in reply to: focon
Could it be that one is a "PROJECTED" dimensions and the other a "TRUE" dimension?
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
focon
in reply to: focon
thank you for your advices and comment. Importing the dimensions didnt work.
but i was now determined to solve this, and did it! If, for some reason, the model has not been grounded or constraint to a plane of origin (XYZ), the dimensions on the drawing will come out as random.
Cadmanto
in reply to: focon
No problem.
Advice for the future, I always make sure that my sketches are fully constrained for various reasons.
This be one of them!!!  If they are not constrained then one never knows what effects it will have on a model.
Something so simple can cause major headaches such as this.
Glad you figured it out.
Best Regards,
Scott McFadden
JDMather
in reply to: focon
@focon wrote:
... the model has not been grounded or constraint to a plane of origin (XYZ), the dimensions on the drawing will come out as random.
It is not random.  It is Projected rather than True.
When you place or edit the dimension right click and select True.
