Inventor General
New Member
denick
Message 1 of 3 (98 Views)
Accepted Solution
Drawing based .ipn shows trimming surfaces even visibility is turned off.
98 Views, 2 Replies
10-01-2012 10:51 AM
Drawing based on .ipn shows (should not show) surfaces used to trim, even their visibility are turned off.
Drawing is normal if based on .iam.
Only one part of the assembly is the problem. Other parts, also with trimming surfaces, are shown normal.
Please see images in .pdf attached.  Thank you!
*Pro
jletcher
Message 2 of 3 (92 Views)
Re: Drawing based .ipn shows trimming surfaces even visibility is turned off.
10-01-2012 11:01 AM in reply to: denick
Can you post the part that is doing this I will test on my machine see what I get.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
New Member
denick
Message 3 of 3 (66 Views)
10-02-2012 07:32 AM in reply to: jletcher
That simptom only happened when the .idw was generated from a .ipn that was generated with view representation of .iam set 'master'. Othervise it was normal, so I use now a view representation other than master to create .ipn for this assembly.
So I found this solution, and give this subject as solved.
Thank you Mr. James.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
