Hello everyone,
Is there a way to make the "Use Quadrant" option by default when placing andular dimensions in drawings (instead of right-clicking-->Options-->Use Quadrant (see attached) every single time I place an angular dimension)?
I'm sure it's possible, I just can't find the option to do that...
Thanks in advance,
B.
Solved by Nicolas.Bourquin. Go to Solution.
Hi Z.baczo,
Probably what you are looking for can be set in the dimension style as indicated in the picture here below.
Note 1: to enable this change for all the future drawings, you could make this modification directly in the dimension style of your template(s).
Note 2: it is also possible to save this change in the "style library" as indicated in the second picture here below..
I hope that can help you.
Best Regards.
Hi Tatiana,
I cannot seem to reproduce the "Use Quadrant" issue on 2023.3.1 update. If possible, please share the file that exhibits the defective behavior.
Many thanks!
