Yes, I know..... 🙂
Dennis Jeffrey, AICE, MICE
260-312-6188
Instructor/Author/Sr. App Engr.
Inventor 11 Professional SP2
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
"Kevin Kuo (Autodesk)" wrote in message
news:5535193@discussion.autodesk.com...
Inventor.exe left running after DRTW quits was addressed in 2008.
Kevin Kuo
kevinDOTkuoATautodeskDOTcom
Inventor Developer
"Dennis Jeffrey" wrote in message
news:5531592@discussion.autodesk.com...
I tried the 9 to 10, but the customer template was at R11 level. However, I
fopund that the template was corrupted. another worked OK in DTW R11.
Yes, the darn thing multiplies faster than rabbits....
260-312-6188
"Hal Gwin" wrote in message
news:5531463@discussion.autodesk.com...
I would try migrating the R9 file first.
Side question ... have you noticed the Inventor.exe still running after
you have finished running the wizard? I find it still running even
after successful wizard operation.
Dennis Jeffrey wrote:
> I've reviewed prior posts on the NG related to R11 SP2 and I've failed to
> find an answer to this issue.
> 1. I have NO instances of Invenentor.exe running prior to launching
> Drawing
> Transfer Wizard 11.
> 2. I select the source idw with no issues. I'm transferring everything
> from
> some R9 templates for a customer. These files contain layers not present
> in
> the R11 original templates.
> 3. I select a new (blank) idw created from an Inventor 11 standard
> template.
> Pick next
Hal Gwin
Mechanical Designer
Caliper LifeSciences
R11 Pro SP2
XP Pro SP2
Dell Precision 650
Dual 2.66 GHz Xeon
3 GB DDR
Quadro FX 3000
nVidia 6.14.10.9136 w/registry update
Dell UltraSharp 24" Widescreen LCD
