Inventor General
Valued Contributor
mikejones
Message 11 of 14 (225 Views)
Re: Drawing Templates and Title Blocks
04-16-2013 06:51 AM in reply to: SeanFarr
Yes that's correct. The one template could be metric or imperial aswell as it is the styles used which dictate dimension types etc. The ilogic I use changes the sheet size, border and title block and if swapping to or from A0 size sheets it also changes the active style to account for different text heights.
Mike
Autodesk Certified Professional
Valued Contributor
mikejones
Message 12 of 14 (215 Views)
04-16-2013 01:11 PM in reply to: SeanFarr
I   have attached the template file in the end as I could think how to strip out the iLogic code and the iLogic form.
The form is instigated by the iTrigger icon and relies on a pre-defined user parameter which is a list of sheet sizes. Once selected the code looks at the user parameter and swaps out the border and title block accordingly. I'm sure the code could be a lot neater but it works so thats good enough for me :smileyhappy:
Mike
Valued Mentor
SeanFarr
Message 13 of 14 (214 Views)
04-16-2013 01:19 PM in reply to: mikejones
Thanks! I'll take a look once I'm back in the office tomorrow...
Sean Farr
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
Valued Mentor
SeanFarr
Message 14 of 14 (194 Views)
04-17-2013 05:45 AM in reply to: mikejones
Template will help me get going in the right direction, I will marked this thread as solved, as it seems that I will be able to create one template file and use iLogic to customize the template to specifics.
Once I get into the iLogic part, I will most likely need some assistance (programming skills are weak) but I will post a new thread in the customization forum.
Thanks All!
Sean Farr
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
