I have an Inventor drawing, in which an Isometric view at 1:2 scale was the first view placed. Then multiple orthographic views at scale 3:4 were placed. Since the orthographic views are the majority of the drawing, I would like the drawing scale to read 3:4, but since the Isometric view was the first placed, it shows 1:2. I have gone into Custom iProperties, and manually changed it there to 3:4, but when I close and reopen the drawing, it changes back to 1:2. I could delete the first Isometric view & re-place it, thus making the Orthographic views the first placed, but I was was wondering if there is another way to do this? I tried to move the Isometric view lower in the tree, but it will not allow me to do so. Thanks
Solved by karthur1. Go to Solution.
Solved by Cadmanto. Go to Solution.
Seems to me that the simple solution might be to delete the iso view and then the second view would become the driving view for the title block.
Then just place the iso view back in at the desired scale.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
That's what I assumed, but since I had balloons & notes attached, I was hoping there was another way. I have done what you suggested, and it corrected my problem, but again, I was hoping there was another way to do it.
There might be. Including maybe some iLogic routine, but if time is of the esense, this was the quickest way I could think of.
If the view has text, balloons, dimensions.... etc. that you want to keep, try this. Make a new sheet in the idw. Activate the sheet with the view you want to move. select it in the browser and drag the view to the new sheet (you will see dark horizontal line in the browser). Now in the new sheet, drag the view back to original sheet (again, you will see the dark line in the browser). It will be placed at the bottom of the model tree when it comes back in.
Its a little more work, but it might save some time in the long run.
Kirk
The quickest way is not to show a drawing scale in the Title Block. Put NTS in the cell where scale factor normally goes. That way you will never have any trouble with someone scaling your drawing with a tape measure.
Best Regards,
Igor.
@kkornocksr wrote:That's what I assumed, but since I had balloons & notes attached, I was hoping there was another way. I have done what you suggested, and it corrected my problem, but again, I was hoping there was another way to do it.
