Inventor Forum
Drawing Path in IDW
1 REPLY 1
164 Views, 1 Reply
Drawing Path in IDW
If there is a way to put the drawing path in the IDW Title Block?
Meaning the location of the file, I know you can make the name of the file appear but the complete path location is something that is very useful.
Another is that in different sheets in the same file. Can you make appear diferent scale automatically, when you set the scale it gives by default this scale to all sheets, even if the views in the sheet is different than the previous.
Thank in adavance for the help.
1 REPLY 1
To get the complete path in the title block use a
property field that consists of
Type = Properties - Drawing
Property = FILENAME AND PATH
For your second question I assume you are looking
for sheets with a predefined "size",
To accomplish this create a new sheet and define
the (custom) size in the "Edit sheet" dialog.
Once you have the correct size, add this sheet to
your Sheet Formats (in the Drawing resources) by using the context menu "Create
Sheet Format".
Use the "New Sheet" context menu from the sheet
format as defined in the drawing resources.
Bob
Inventor Workflow QA
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
If
Meaning the
Another is that
