Inventor General
Member
Message 1 of 5 (1,004 Views)
Drawing Bevel Gears
1004 Views, 4 Replies
09-28-2012 07:06 PM
Hey Guys,
I am trying to draw a bevel gears from drawings, one is a scroll plate and the others are gears with a key hole. As you can see in the following attachment.
My question is how do you draw bevel gears on the face of the scroll plate and the cylindrical face of the other 3 gears?
Cheers
Message 2 of 5 (988 Views)
Re: Drawing Bevel Gears
09-29-2012 04:05 AM in reply to: mini88
I would start with the Gear Generator Design Accelerator in Inventor assembly environment.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 3 of 5 (961 Views)
09-29-2012 07:14 PM in reply to: JDMather
Hey, thanks for the quick reply.
I've tried playing around with the Gear Generator Design Acceerator, but it always outputs new gears rather than making the face of the components into the gears. (See image).
Can you possibly guide me through how to use the Gear Generator Design Accelerator to get it to work?
Message 4 of 5 (935 Views)
09-30-2012 10:44 AM in reply to: mini88
Then simply make the new gears.
Right click and Open.
Finish the desired geometry.
Member
Message 5 of 5 (884 Views)
10-01-2012 09:24 PM in reply to: JDMather
Managed to get it working, thanks JDMaather
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
