If you have an existing balloon stack, and you need to add some balloons to the stack, is there a way to conveniently get the newly added balloons to be in the middle of the stack so they are all in numeric order?
I know you can edit the stack and manually change the stack by overwriting the parametric value.
I also know you can delete the balloons and reselect everything to accomplish this, but I am just wondering if there is a better and smoother way to do this.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
