Inventor Forum
Draw a sketck on top of an imported pdf
8 REPLIES 8
Message 1 of 9
SylvainJ
2480 Views, 8 Replies
I am new to Inventor, I read several posts without finding a solution to my problem:
I have to rebuild 3d geometry from existing *.pdf drawings.
What would be the best way to proceede?
I thought an option would be to import the *.pdf in a kind of layer, rescale it and sketch on top of it.
However the pdf importation fails.
Do you know how to import a *.pdf in sketch mode?
Do you have better solutions to propose?
Thank you for your support,
Best regards,
SylvainJ
8 REPLIES 8
Message 2 of 9
mpatchus
in reply to: SylvainJ
You could convert the PDF to an image file (JPG, BMP< etc.), then import the image to the sketch.
Then use the image as a guide to create your geometry.
We have done this in the past for certain parts.
However, we have found that it is much faster just to create the geometry without using the images.
But you can try it.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 9
SylvainJ
in reply to: mpatchus
Thank you for your suggestion.
It works just fine !
The fact is that I don't have many space to unfold large drawings at my desk.
With your solution, I'm able to zoom on the drawing and sketch on top of it.
Thanks again
SylvainJ
Message 4 of 9
rky001
my friend you can directly connvert pdf to dxf/ dwg. You just need a pdf convrter. there is a lot of pdf to dxf converter in market free of cost.
...............make it easier....................Smiley Happy
Message 5 of 9
blair
in reply to: rky001
Done this with Autocad, take a good high quality picture with either a large format ruler or have the overall dimension of the object. Bring the picture into a Acad drawing and adjust the scale until it's the correct size. Then draw on top of the picture.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 9
rky001
in reply to: blair
but my friend how to bring picture in auto cad...............can you please explain it briflly so that i can understand
note : via using pdf converte you can convert dozen of files in one time.
we share we GrowSmiley Happy
Message 7 of 9
JDMather
in reply to: rky001
@rky001 wrote:
..... how to bring picture in auto cad..........
AutoCAD?  or Autodesk Inventor?
The AutoCAD forum is over here http://forums.autodesk.com/t5/AutoCAD-2013-2014/bd-p/706
To bring a picture into Inventor start a new sketch.
Place the image, add dimensions size and locate the image relative to the origin.
Exit sketch.
Start new sketch to use the image as reference.
Message 8 of 9
rky001
in reply to: JDMather
 i think, we can dirctly type xrf in command line and click on option defined there- can take pdf to auto cad but it will not be editable,but m y question is i want to make it editable...............
 so how can i make it possible with autocad.
..........make it sorter.......
Message 9 of 9
JDMather
in reply to: rky001
@rky001 wrote:
....command line...............
This is the Autodesk Inventor forum.  Autodesk Inventor does not have a command line.
I recommend that you post AutoCAD questions over at that forum.
