Inventor Forum
Does Inventor 2014 crash more than Inventor 2013?
14 REPLIES 14
Message 1 of 15
oransen
921 Views, 14 Replies
I've just been testing my programs with Inventor 2014 and I get five or six crashes a day.
With 2013 I can't remember the last crash I had.
So does Inventor 2014 crash more than Inventor 2013?
14 REPLIES 14
Message 2 of 15
csaba.stupak
in reply to: oransen
Could you provide the steps to recreate this crash so we can reproduce the issue?
If it is dataset dependent, could you send us the dataset?
Csaba
Message 3 of 15
oransen
in reply to: csaba.stupak
I've been sending the error reports as requested by the Inventor Crash Handler.
Message 4 of 15
mcgyvr
So far the program itself has been VERY stable to me..
I can't remember when it crashed (if at all)..
BUT I always take the time to properly update graphics drivers/turn off AV programs/disable UAC/clean temp files,etc.. prior to install.
Message 5 of 15
Mario428
I went from 2012 to 2014 and find 2014 much more stable.
Had one crash last week, do not remember the previous one and the 6 other users here I beleive find the same thing.
Message 6 of 15
bob_holland
Owen,
I check our crash reports and could not find any associated to the domain that you use for your forum login.
Can you please provide me with the email address that you are submitting the CERs under.
This way, I will be able to check the reports and see what we might be able to do for you.
Thank you.
Bob Holland
Autodesk Product Support
Message 7 of 15
oransen
in reply to: bob_holland
I have Inventor installed on a laptop I take around with me, but I'll see what I can do.
Anyway the crash was sometimes folloed by a "The graphics card has stopped working and has been restarted" message and I've just seen that there is a new service pack which seems to correct some graphics card errors...
I'll give that a go and let you know,
Message 8 of 15
mdavis22569
What is the Video Card in the laptop? Also what do you have in your application options for graphic settings....? It sounds like you have more of a graphics issue than software issue
Mike Davis
Message 9 of 15
bob_holland
Owen,
I would like to have you create the following two reports off of the computer that is experiencing the issue:
Inventor Diagnostics
Microsoft DxDiag
I have attached two PDFs to assist you if needed.
Bob Holland
Message 10 of 15
Mario428
in reply to: Mario428
LOL, Murphy's law does apply, less than an hour after I posted Inventor crashed. But I was pushing the limits with a couple of big IDW files open and trying to update the large assembly
Message 11 of 15
oransen
Ok, got them. I've just installed Service Pack 1 - Update 3, hope I don't need them
Message 12 of 15
bob_holland
Owen,
Does this mean that your Inventor is no longer crashing?
Thank you.
Bob Holland
Message 13 of 15
oransen
It seems to crash less. I send the crash reports with my email address: help at ransen.com. I need to test more...
Message 14 of 15
Mark_Wigan
2014 is fine but i and lots of people i work with set the graphics to compatibility mode if it has issues (after installing all service pack / updates & updating your vid drivers etc of course)
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
Message 15 of 15
oransen
in reply to: Mark_Wigan
"2014 is fine but i and lots of people i work with set the graphics to compatibility mode if it has issues (after installing all service pack / updates & updating your vid drivers etc of course)"
You mean "compatible with previous versions of Inventor mode" in the Inventor options dialog?
