Inventor General
Valued Mentor
Message 1 of 3 (456 Views)
Do I need to migrate Custom Inventor Material Library from 2013 to 2014
456 Views, 2 Replies
08-28-2013 08:41 AM
I created a custom Inventor Material Library using Inventor 2013.  I want to use that library in Inventor 2014.  I renamed the "out of the box" Inventor 2014 Material Library and copied the Inventor 2013 Custom Inventor Material library to the shared network location we use for our Inventor styles library.  I am able to to see our custom Inventor material library in Inventor 2014.  DO I NEED TO MIGRATE IT FOR INVENTOR 2014.
What is the proper procedure when you upgrade Inventor and you have a custom Inventor material library?  Do you just copy the custom library to the design data folder and start to use it, or do you use the 'out of the box" Inventor Material Library and copy the custom materials to the that library every year.
Any help would really be appreciated.
Thanks!
John C Weiss Jr.
CAD Administrator
Follett Corporation
Employee
Message 2 of 3 (437 Views)
Re: Do I need to migrate Custom Inventor Material Library from 2013 to 2014
08-28-2013 01:48 PM in reply to: jweiss
John,
There is no need to migrate an .adsklib file from 2013 to 2014. You can simply copy it in to the desired location & ensure it's referenced from your project settings. Note that once you've written new data to an adsklib file from 2014, you might experience issue if you try to use the exact same file with 2013, though, so ensure you keep your versions separate, if required.
In general, I'd suggest leaving the Inventor library in it's as-shipped form & adding your own custom materials/appearances to your own custom library, as opposed to making changes to the Inventor library.
Hope this helps,
Chris
Chris Mitchell
Inventor Customer Enagagement Team
Valued Mentor
Message 3 of 3 (434 Views)
08-28-2013 01:50 PM in reply to: ChrisMitchell01
Thanks for the information Chris!
John C Weiss Jr.
CAD Administrator
Follett Corporation
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
