Inventor General
Member
sozsoylu
Message 1 of 5 (280 Views)
Distribution of assembly weight to legs of a structure
280 Views, 4 Replies
04-27-2012 11:56 AM
I have an assembly of parts that are on a stand thathas four (4) legs. If you were to distribute the load from CoG there will be vertical forces as well as moments on each pad that will support this assembly. Is there a way for Inventor to show the distribution of the CoG load on the given points?
*Expert Elite*
JDMather
Message 2 of 5 (259 Views)
Re: Distribution of assembly weight to legs of a structure
04-27-2012 06:15 PM in reply to: sozsoylu
Dynamic Simulation
Attach your assembly here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
Alvaro.perez
Message 3 of 5 (105 Views)
01-28-2014 02:31 PM in reply to: sozsoylu
Does Anybody know how to figure out the weight under the legs of a structure after applying gravity to the top? Please help
*Expert Elite*
JDMather
Message 4 of 5 (97 Views)
01-28-2014 03:14 PM in reply to: Alvaro.perez
Apply Fixed constraints to the bottoms of the legs.
Add the load.
Run the simulation.
Right click on one of the fixed constraints and select Reaction Force.
Attach your assembly here.  (my previous response was over-kill, don't need DS)
Member
Alvaro.perez
Message 5 of 5 (72 Views)
01-29-2014 07:21 AM in reply to: sozsoylu
Thank you. That was very helpful.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
