Inventor Forum
Distribution of assembly weight to legs of a structure
4 REPLIES 4
sozsoylu
1140 Views, 4 Replies
I have an assembly of parts that are on a stand thathas four (4) legs. If you were to distribute the load from CoG there will be vertical forces as well as moments on each pad that will support this assembly. Is there a way for Inventor to show the distribution of the CoG load on the given points?
4 REPLIES 4
JDMather
in reply to: sozsoylu
Dynamic Simulation
Attach your assembly here.
Alvaro.perez
Does Anybody know how to figure out the weight under the legs of a structure after applying gravity to the top? Please help
JDMather
in reply to: Alvaro.perez
Apply Fixed constraints to the bottoms of the legs.
Add the load.
Run the simulation.
Right click on one of the fixed constraints and select Reaction Force.
Attach your assembly here.  (my previous response was over-kill, don't need DS)
Alvaro.perez
Thank you. That was very helpful.
