Recently upgraded from Inventor 10 to 2014...Big Leap.
When in an assembly...editing a part, I switch to wireframe mode and only the edited part shows?
I want to see all of the assmebly..
Brian
Solved by bmclouth. Go to Solution.
Brian,
I have seen several postings lately in regards to display issues with 2014. Did you load the latest service packs as well when you upgraded?
Did you do a clean install when you loaded it? Meaning you completely uninstalled 2010 and then loaded 2014.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@bmclouth wrote:
Quick reply..Thanks
I uprgraded from 10 (2005 released)....not 2010. Super big jump.
Hi bmclouth,
When making a jump of that many versions it's recommended that you migrate your files. Particularly if you see things not behaving as expected when working with your existing Inventor files. There are 3 ways to do this, so you can decide which is right for you, but I thought I'd remind you of this in case you start seeing "weirdness".
On Demand Migration
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-C75DF198-54D5-468F-961B-83D47EF7B49B
Migrate Command
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8BD7003D-D430-48A8-BF15-FE8F807F89F7
Batch Migrate files using Task Scheduler
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-873B3D0D-E1D7-4CF3-BFC3-1956B43389F2
Data Migration General Info
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FB9B4422-2348-46FA-964B-7845D9D96018
Also, in case you're wanting a quick look through the What's New, since Inventor 10:
http://inventortopix.blogspot.com/p/whats-new-docs.html
I hope this helps.
Curtis
