Inventor General
Active Contributor
Message 1 of 3 (175 Views)
Accepted Solution
Display Area for a Drawing Section in a Drawing Text Box
175 Views, 2 Replies
10-17-2011 11:48 AM
How do I calculate the area for a section of an extruded profile and display it in a drawing note?  I see how to add a field <AREA> in the text dialog box, but it comes up as N/A in my text box in the drawing.  This is also the case for <MASS> and <VOLUME>.  How do I get the drawing fields associated with the physical properties of the model?
Kevin
*Expert Elite*
Message 2 of 3 (170 Views)
Re: Display Area for a Drawing Section in a Drawing Text Box
10-17-2011 11:53 AM in reply to: kegle
update the mass props of the object.
I'll bet that the area prop is the surface area of the object, not a cross-sectional area.
Inventor 2014
Vault Professional 2014
Active Contributor
Message 3 of 3 (161 Views)
10-17-2011 12:48 PM in reply to: swalton
You are correct.  I was able to get the field properties to display by going to the model and calculating the physical properties.
The area is the surface area which I do not want.
I figured out to get what I really want which is lbs/foot of a profile.  I created a sketch on the extrusion and created a reference dimension and renamed it "Length".  I then created a user parameter named LBperFT.  Then I created an iLogic rule and defined LBperFT = iProperties.mass / Length.  In the drawing note I displayed the user parameter LBperFT.
This seems to work.  Is there a better way to do this?  This will not be accurate if I have other features added to my extrusion such as holes and cuts.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
