Inventor General
mlevko
Message 11 of 31 (418 Views)
Re: Disappearing menus in Inv 2012
05-17-2011 07:55 AM in reply to: mlevko
Hello Johnson,
It was on and I disabled it to have the "old" menus workable. I worked with the downloaded trial version until I got the purchased package (very nice disk on key). In the trial version the Marking menu worked at least for few minutes and then "retired". Now it is not working at all. The "Select other" snap point doesn't work at all and it is very disturbing when measuring distances. In the trial version the "Select other" also worked for sometime.
The computer is Z400 DELL workstation, 4 gb memory, XP Pro 32 OS and Quadro FX 1800 video card with 750 Mb memory. The driver is the latest driver 270.71 from NVidia.
The Inventor 2009 Pro is installed on the same computer.
Today the Inv 2012 freezed several times and I had to close it using Task Manager.
My office email is mlevko@iai.co.il and my cellular is +972-52-612-6900 if you need more info.
Michael
Employee
Message 12 of 31 (411 Views)
05-17-2011 08:03 AM in reply to: mlevko
Michael,
The behavior you are describing does not sound right but it is the first time I heard about it. Could you try something for me real quick and see if it can resolve the issue?
Go to Tools tab -> Application Options -> Hardware -> choose Compatibility mode and check Software graphics option -> Apply -> OK. Then restart Inventor.
After that, does it help?
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
mlevko
Message 13 of 31 (396 Views)
05-17-2011 08:35 AM in reply to: mlevko
I will check it tomorrow in the office and let you know.
Michael
Distinguished Contributor
Message 14 of 31 (367 Views)
05-18-2011 06:19 AM in reply to: mlevko
I have heard from support that the select other not showing up has been reported to development and they are working on a fix. They say that it seems to most commonly occur after using the Create in Place command in an Assembly. I have not found that to be the case for me.  As soon as I open Inventor, if I try to use the measure tool using the select other command, it doesn't work, even before I have used the Create in Place command.  Can anyone else verify this?
mlevko
Message 15 of 31 (356 Views)
05-18-2011 09:40 AM in reply to: mlevko
:smileymad:
After I installed the purchased version, the Marking menu AND "Select other" DON'T WORK AT ALL!! As I explained before, the Marking menus are simply HIDDEN there and if go with the cursor to the place some option is there, as I remember, and click this option is activated. The Marking menu should be called "Memory Training" menu.
Message 16 of 31 (351 Views)
05-18-2011 12:16 PM in reply to: mlevko
Just thought everyone would like to know that I have fixed the marking menu right click problem twice now by doing a Check Disk on my hard drive with the “Automatically fix file system errors” and “Scan for and attempt recovery of bad sectors” both checked. It does not however, fix the select other problem.  I had the marking menus back, but still no "select other" menu so I did a re-install and after I did that both did not work again.  So since the check disk of my hard drive seemed to have fixed it the first time, even though I did it for a different reason, I decided to try it again and it fixed it again.  I just wish I could figure out something for the "select other" menu now.
Valued Contributor hlo
Valued Contributor
Message 17 of 31 (343 Views)
05-18-2011 09:18 PM in reply to: shastu
IH
i also have this problem with disappearing menu, i found out I my case, than it was controlled by my resolution, when I change to a low resolution all menus came back. I hope Autodesk will solve this problem soon.
Regards
Henrik
*Pro
Message 18 of 31 (340 Views)
05-18-2011 09:50 PM in reply to: hlo
Again, I'd suspect graphics. I have 8 installs so far of 2012 on both Win7 and xp64 systems. No problems with marking menus or select other.
hlo wrote:
IH
Regards
Henrik
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Active Member
daltec2
Message 19 of 31 (343 Views)
05-18-2011 11:53 PM in reply to: mlevko
Mine is checked but still the same problem.
mlevko
Message 20 of 31 (321 Views)
05-19-2011 09:21 AM in reply to: mlevko
Today I checked on my office computer and you are right. When I changed the resolution from 1920x1200 to 1600x1000 (same ratio) both menus started to work!! Well done. I hope that Autodesk will fix it soon.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
