Inventor General
*Pro
sbixler
Message 11 of 21 (355 Views)
Re: Disappearing Views and Text - Inventor 2013
09-10-2012 09:56 AM in reply to: timchr
I don't have anything else to suggest.  We have a couple of FX1800s here on stations that are not in regular use and we haven't yet moved to 2013.  They're pretty old by this time (in computer years!), not capable of DirectX 11, but they still work with Inventor 2012.
Distinguished Mentor
john.retzlaff
Message 12 of 21 (335 Views)
09-11-2012 08:19 AM in reply to: sbixler
I have a workstation here running FX1800 on IV2013 with no problems.
John Retzlaff
Active Member
trevorauman
Message 13 of 21 (292 Views)
12-14-2012 09:33 AM in reply to: sbixler
I have the same problem. I have not installed an updates yet, but if it is any help to autodesk to know more about the problem, it only occurs for me when I am scrolling in and out on the drawing and moving my cursor over a view at the same time. If I leave the cursor over a single view or over the blank portions then it does nto occur. Makes me think it is a software issue maybe.
I am running:
Base: Lenovo ThinkStation S20
CPU: W3550 @ 3.07 GHz
RAM: 16 GB
GPU: Quadro 2000 1 GB - Driver is 276.42
SSD: SanDisk 120 GB
By no means is it an "old machine" - and I have the same issue.
Distinguished Contributor
JimSteinmeyer
Message 14 of 21 (284 Views)
12-14-2012 01:31 PM in reply to: trevorauman
I too am experiancing this issue. My thought was simply that I didn't have enough machine and that I would have to live with it. Not to sound bad but I am happy that someone else is having the issue too. Maybe it isn't my machine. (even though it is a WalMart Black Friday $500 machine that is 4 years old :smileylol:)
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
Active Contributor
timchr
Message 15 of 21 (280 Views)
12-14-2012 01:39 PM in reply to: sbixler
Yep, we are still having the issue here as well on multiple machines. I hoping a new graphics card in a new PC next release will solve the issue. We are going to move to the Nvidia 4000 card.
*Expert Elite*
Curtis_Waguespack
Message 16 of 21 (272 Views)
12-14-2012 01:51 PM in reply to: timchr
Hi timchr,
This is a bit of a wild guess, but do you have an Nvidia control panel or something similar where you can set the 3D settings to favor performance over quality. I have one older workstation where we see flakey graphics in the drawings and in the model browsers when this is not set to maximum performance.
If you make a change such as this, you have to restart Inventor for the changes to take place.
It's just something to check.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
trevorauman
Message 17 of 21 (265 Views)
12-14-2012 02:05 PM in reply to: timchr
My IT department is convinced that it is my RAM, so they pulled 8 of the 16 gigs. It has only been a couple of hours, but I have not been able to repeat the problem. The reason we think this might be the issue is becasue I had a Vault error before we upgraded to 2013 that was RAM related. I will keep you posted, but I have my concerns since timchr is having the issue on multiple machines.
tfuhrmann
Message 18 of 21 (212 Views)
02-01-2013 07:17 AM in reply to: timchr
Same issues here as well. Tried Nvidia and ATI cards along with various drivers. Been working with Autodesk support for a couple months now. They seem convinced it's a video card/ driver issue, but I feel it's a bug in the software. Seen a few threads now discussing this and it's happening with various cards/drivers. Some "fixes" seem to work in the short term but the disappearing act keeps coming back. Found it's apparently linked to views with breaks in them. Never seen it on an idw without a break and if it does happen I can delete the view or break and problem goes away.
Active Member
trevorauman
Message 19 of 21 (201 Views)
02-01-2013 08:38 AM in reply to: tfuhrmann
As a follow up. Once I pulled my bad RAM I did not have the problem randomly any longer, but it would happen when my computer went to sleep / logon screen. IT did a service pack on VAULT and I think INVENTOR and I no longer have the problem.
Active Contributor
NathanGMartin
Message 20 of 21 (199 Views)
02-01-2013 08:57 AM in reply to: timchr
I wil second this problem, and offer the only fix that searching through the forums has yielded to me: save, close inventor, & re-open.
I didn't say you'd like the fix, and I don't either.
Nearest I can figure after reading through these forums, on a machine with all updates and fresh graphics drivers, the issue persists simply due to Inventor's consumption of system resources on low-to-medium range machines.  This has been happenening to me ever since I started working with Inventor.
Good luck.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
