In a drawing I have multiple sheets to show different pipe runs in the same assembly. I create seperate levels of detail and suppress the pipe runs I do not want to show for each sheet view. Next I insert a view into a sheet and select a level of detail for that view. I only have one view per sheet. Here is my problem:
Say I insert a view showing only pipe run "A" into Sheet 1 of my drawing. Then I insert a view showing only pipe run "B" into Sheet 2. So on and so forth.
When I save the drawing it sometimes will prompt me to save the assembly as well. If I check 'yes' to save both the drawing and assembly in the same prompt, Inventor crashes. If I save only the drawing, the next time I save it still asks me to save the assembly. If I check 'yes' to save the assembly and 'no' on the drawing, the red lightning symbol appears on a few of my sheets. When I activate those sheets so that they update, the piping is missing, nothing else. I have found a way around this, but it is annoying and I would like to find a way to resolve it without the next steps.
To resolve it I activate my assembly tab. Then I activate each level of detail in the assembly, one by one and save each one. Then I go back to my drawing tab. sometimes the lightning bolt appears next to the sheets, but the piping does not disappear doing it this way. This happens quite often when I am saving my drawings and has been very frustrating, especially when my piping disappears along with any labeling connected to it.
My question is: Why are you using LOD to show a single pipe run? Each pipe run is (or should be) created as a sub-assembly of the main assembly, and can be shown as such for detailing on a drawing sheet.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
