Inventor General
Active Member
Message 1 of 9 (212 Views)
Disapearing Dimension lines
212 Views, 8 Replies
05-17-2012 12:28 PM
Hello
I have a problem with Inventor 2013. The dimension lines have disapeared and I have no idea how to bring them back. I've been through all  the  dimension styles and layers to make sure I hadn't turned one off
All other drawings are fine and if I create another even using the same model it works just fine but I'd rather find out why than re-do the whole drawing.
 Here's an example of the problem
Inventor 2013 RTM Build 138 HP
XW4600 Workstation - E8500@3.16GHz - 3GB RAM
Win XP 32bits - NVidia Quadro FX 1700
*Expert Elite*
Cadmanto
Message 2 of 9 (208 Views)
Re: Disapearing Dimension lines
05-17-2012 12:34 PM in reply to: Gvallee
I am not using 2013 yet, but if you do a print preview are they there?
Also, I know you have checked the new dim style settings, but did you look at these settings?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Expert Elite*
mrattray
Message 3 of 9 (201 Views)
05-17-2012 12:40 PM in reply to: Gvallee
Did you try a reboot?
Mike (not Matt) Rattray
Active Member
Message 4 of 9 (198 Views)
05-17-2012 12:41 PM in reply to: Cadmanto
Thanks for the quick response
print preview and actually printing the file shows exactly the same result as the screenshot.
I also tried both of these settings to no avail.
Active Member
Message 5 of 9 (197 Views)
05-17-2012 12:42 PM in reply to: mrattray
I tried rebooting and I also tried opening the drawing on 2 other computers
*Expert Elite*
Cadmanto
Message 6 of 9 (189 Views)
05-17-2012 01:02 PM in reply to: Gvallee
You wouldn't happen to still have 2012 running somewhere to try this would you?
If so and it shows the extention lines I would say you uncovered a bug in the software.
Best Regards,
Scott McFadden
Valued Mentor
RayFeiler
Message 7 of 9 (177 Views)
05-17-2012 01:30 PM in reply to: Gvallee
Someone else with the same issue.
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-missing-dimensions-in-drawing/td-p/346...
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Active Member
Message 8 of 9 (174 Views)
05-17-2012 01:34 PM in reply to: RayFeiler
Thank you, I hadn't found anyone else with the same issue.
I also noticed that page 1 of my drawing is perfectly fine while page 2 is broken. I am starting over the drawing as it probably will be faster than trying to salvage the old one.
*Expert Elite*
mrattray
Message 9 of 9 (172 Views)
05-17-2012 01:37 PM in reply to: Gvallee
Maybe they'll fix it in IV 2017.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
