Is there a way to disable the level of detail? I personally find this feature most annoying.
I am now starting to understand it after being tripped up by it early in my Inventor carrier.
But even now in understanding it more, I see no point in it.
The problem I have is I can have more then one level of detail in my model to show a specific way in my
one drawing. Then this specific level of detail when changed for a different drawing will screw with the first drawing.
Why can't one just suppress certain items without having to worry about this. Heck, isn't this what Iparts and iassemblies are for?
Solved by jtylerbc. Go to Solution.
I used to use Solidworks back in the day, and from memory (I could be wrong), suppression in Solidworks is a kin to Inventors iAssemblies. Users who jump into Inventor and start suppressing parts usually don't realise that what they're actually after is Inventors iAssemblies and not Level Of Detail suppression.
This leads to the second problem; an Inventor assembly that's been mis-configured with multiple LODs at both top level and sub-level assemblies would be an absolute nightmare to navigate and correct. I'd advise against using Inventor LOD and suppression until you're absolutely 100% sure of what it does and what's it's for.
If you're using Inventor and you're suppressing parts without fully understanding LOD, stop yourself, then read up on both Level Of Detail and iAssemblies, because you're probably after the iAssembly functionality.
Cheers,
Karl
Karl,
As far as Solidworks goes you could suppress an item and it would remove it from memory, but it did not cause the same grief and confusion that LOD's cause in Inventor.
I get more now since I first started this thread on how the LOD's work, but they still have to be handled with care.
But you are correct in that when you start using LOD's in sub assemblies you have to know what you are doing.
We had our VAR in last week and he sat down with me and did some very good explaining and Like I said I have a better understanding of it.
I had a huge nightmare with LOD's as well coming from a SW background. You have to just accept that suppress in IV is something completely different from suppress in SW and that there is no real direct IV equivelent to SW's supress/ configuration functions. Sure there's iAssemblies, but that's really not the same thing either.
