Hi
is there anybody here to have an tutorial how to draw chair frame like this?Or any people here have suggestion how do i drawn it? what feature should I deal with it.
thank you
Samsul H.
Solved by JDMather. Go to Solution.
I'd build this up through 2D sketches where possible. From a cursory glance you should be able to create 2D sketches for the base, seat, front legs, rear leg/back. Do one of the arms as a 3D sketch, then mirror it. Finally use your sketches as paths for sweeps.
See this tutorial for technique.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
post back with your ipt attempt if you can't figure it out.
The CADWhisperer YouTube Channel
Hi JDMather
I try to use your method and I can't draw the sketch 2 like yours. I was confused where should I put the sketch to draw the sketch 2. So I make it with my own way but the path doesnt matched correctly. Here my attempt
thank you
Best regards
Samsul H.
@samsulhadi wrote:Hi JDMather
Here my attempt
thank you
Attach *.ipt file here.
You will create a 2d sketch on the XY plane and another on the YZ plane to project the 3D intersection for the arms.
The rest is all 2d sketches.
I only had a few minutes to spend on this - but should not bee too difficult.
Do you have any dimensions to go by? Where did your original image come from?
Ok JDM I got it and thank you very much. Actually I dont have the dimension too because the original image was my friend tagged me in facebook. and he challenge me how I doing that with Inventor...again.. thank you 🙂 here my result.
It is no longer necessary to Extrude the surfaces to get the Intersection Curve. You can do this with the 2 2d-sketches in the 3d sketch.
