Inventor General
Distinguished Contributor
TONELLAL
Message 1 of 3 (314 Views)
Dimensions in sketch symbol
314 Views, 2 Replies
07-30-2010 03:18 AM
I need to create skech symbols to illustrate mounting schemes, so without scale. I need to put dimensions in the symbol, which are only annotation, not parametric. This dimension must be visible once the symbol inserted on the sheet.
When I create the dimension in the sketch, it is always a paramertric dimension, which drve the drawing and is not visible in the inserted symbol.. How can I do to have only an annotation ? (I precise the option "sketch only" does not function on dimensions)
Product Support
francesco.tonioni
Message 2 of 3 (293 Views)
Re: Dimensions in sketch symbol
07-30-2010 08:02 AM in reply to: TONELLAL
You can set it as driven, it will not drive the symbol geometry but it will follow the geometry of the symbol anyway.
If you need to insert your own text I suggest to draw it (draw arrows and text) or draw the symbol and dims in autocad, explode them then insert them in the Inventor symbol sketch.
Regards
Francesco
Francesco Tonioni
Support Specialist
Product Support
Valued Contributor
floccipier
Message 3 of 3 (107 Views)
02-29-2012 05:01 AM in reply to: francesco.tonioni
Even the dimensions are driven they don't appear.
broken dimension's text brought from Autocad broken become so crap and dimmed in view and prints.
Any other solution?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
