Inventor General
Valued Contributor
Scott_Stubbington
Message 1 of 6 (799 Views)
Dimensions flipping direction - IV2013
799 Views, 5 Replies
11-21-2012 04:43 AM
I have a skeletal master part and in one of the sketches one of the dimensions flips direction, if this dimension was defined with a positive direction of 12 o'clock(20120725-DimensionChangeDirection0.jpg), over time and changes, the
positive direction will flip to now being 6 o'clock(20120725-DimensionChangeDirection1.jpg) and it doesn't break the model, but I now have less holes than required.
Anyone else seen this? If so, any recommendations?
I will not upload models.
Scott
Valued Contributor
conklinjm
Message 2 of 6 (769 Views)
Re: Dimensions flipping direction - IV2013
11-21-2012 07:29 AM in reply to: Scott_Stubbington
Many times ... one of the problems with both linear and angular dimensions within a sketch is that they don't actually have an associated vector direction or rotational reference.
Depending on the complexity of the sketch/part; one solution is to use workplanes (which do have direction vectors) and project them into the sketch to define your geometry.
HTH
cwhetten
Message 3 of 6 (755 Views)
11-21-2012 08:13 AM in reply to: Scott_Stubbington
The only time I have seen this happen is if at some point the value of the dimension was set to 0, then changed to a non-zero value.
As conklinjm says, the sketch dimensions don't have an absolute direction.  So when changing a zero value to a non-zero value, the direction that it decides to go is unpredictable.
If you know that your parameters can have values such that your dimension can be 0, then it is best to define that dimension in another way to avoid this problem.
Valued Contributor
Scott_Stubbington
Message 4 of 6 (752 Views)
11-21-2012 08:26 AM in reply to: cwhetten
Your solution of Workplanes is superb conklin, thank you. :-)
I figured there may be a problem with direction when a dimension value = 0, but when I analysed the values these are occurrences of zero are very few, however pretty much every time I edited this assembly, the holes are flipping direction.
Thanks for you help people.
Regards
Scott
Member
guilloryt
Message 5 of 6 (644 Views)
12-09-2012 07:53 AM in reply to: Scott_Stubbington
I am having this exact problem. Would you provide an example or more detail of projecting the workplane into the sketch to resovle the problem?
Valued Contributor
Scott_Stubbington
Message 6 of 6 (629 Views)
12-09-2012 11:53 AM in reply to: Scott_Stubbington
Under my circumstances, I had a dimension that was controlling the position of a hole on a 2D sketch, an equation was driving the dimension.  In order to have a Workplane drive the position, I copied the quation from the dimension and changed it to a driven dimension type, the sketch was closed, EOP marker was moved above the sketch and a workplane was then created using the equation from the dimension, I endured a couple of circular reference errors with the equation but managed to remove them by changing the equation properties.  I moved the EOP marker back to the bottom, edited the sketch to now include the newly created workplane and constrained my hole centre to the projected geometry.
HTH
Scott
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
