Inventor Forum
Dimensioning error in drawing. Inv 2013 pro.
3 REPLIES 3
trumpy81
719 Views, 3 Replies
I was just doing some drawings and found a very strange dimension.
See the attached pic. Its the dimension in section J-J (lower Left) It is supposed to be the same as the dimension in Section H-H but as you will see the dimesion it gives is a little strange ... lol
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
3 REPLIES 3
SBix26
in reply to: trumpy81
No idea what happened there.  However, standard drafting practice is to dimension to centerlines of holes, not to section edges.  That might give a better result.
karthur1
Thats a radius dim it putting on the cut edge.  Section J-J is not truly vertical and the view it is cut from in not truly horizontal. Edit the view and rotate it so that the fins are horizontal. Edit the sec line J-J and add a vertical constraint and anchor it to the center of the hole.
trumpy81
in reply to: karthur1
Sam, you are quite correct, in fact I had already added a centerline bisector and re-did both dimensions without error. I just thought it was strange to see such a dimension ... lol
karthur1, I very much doubt that it was picking up a radius, certainly not with that dimension. A 191metre radius is a bit big for these drawings ... lol
Regards
Andy M
