Inventor Forum
Dimension variable question
13 REPLIES 13
Message 1 of 14
237 Views, 13 Replies
I know I asked this already but I wnt to ask again.
When I asked about global variables, Sean directed me to the tutorial.
Great. But I want to know this (yes/no):
example, in sketch mode, you can say d1=d3 and so on for that part file. but
in sketch, can you say d1_in_part2 = d8_in_part6 and so on? can you
refernece dimensions across different parts in sketch mode?
And obviously, these parts would be put into an assembly. Does anybody know
whether this can be done? (yes.no?)
13 REPLIES 13
Message 2 of 14
Yes. In the part you want to reference dimensions from, rename the
dimension(s) you want to use in the other part with logical names. Then
check the Export Parameter checkbox next to these parameter(s). In the part
you want to use the dimensions from the other part, use the Derived
Component tool to derive the Exported Parameters from the first part. You
can elect to derive only the exported parameters. In a dimension edit box,
click the arrrow and select List Parameters to get a list of all renamed
parameters, including the parameters derived from the first part.
HTH
Neil
"Jimmy J" wrote in message
news:B2CD5C336FBEC59C1CE1801AC69659CB@in.WebX.maYIadrTaRb...
but
know
Message 3 of 14
The only gotcha in this is you can't have some dims in one part1 drive
part2, and have some in part2 drive part1. Probably not as big of a deal in
parameters, but with skeleton modeling sometimes you find yourself wishing
you could do something like that.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Neil Munro" wrote in message
news:496E01531000E44E719B6B86CA8BF4B0@in.WebX.maYIadrTaRb...
part
> HTH
> Neil
Message 4 of 14
Is this for IV6 Only?
part
> HTH
> Neil
> but
> know
Message 5 of 14
No. I think it came in 5.0
- drew
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Check out my MDT & Inventor FAQ @ http://www.mymcad.com/
news:430C5DCDE56D01183B4EA792FBD5CA91@in.WebX.maYIadrTaRb...
> part
You
box,
> > HTH
> > Neil
file.
> > but
anybody
> > know
Message 6 of 14
I have been meaning to add this to the embedded and linked parameters
tutorial but keep forgetting...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
part
> HTH
> Neil
> but
> know
Message 7 of 14
Can somebody tell me :
1) what are logical names (is it like d1, d2 d3...)
2) where is the "check the Export Parameter checkbox next to these
parameters?"
3) where is the "click the arrow and select List Parameters...?"
there are bunch more but basically like how I would find these
commands/buttons/and checkboxes
Thanks.
And Sean, since you've got some time over the Christmas, maybe you should
add detail instructioned tutorial on this matter. That'll really be great.
part
> HTH
> Neil
> but
> know
Message 8 of 14
Although embedded in a larger tutorial, here is a link to exporting and
deriving parameters: This tutorial was written for R5, so the UI is slightly
different than R6.
http://makeashorterlink.com/?H3AE223B2
Neil
news:3059FF6E38888793E7B6EDE85EA0D721@in.WebX.maYIadrTaRb...
> parameters?"
> Thanks.
great.
> part
You
box,
> > HTH
> > Neil
file.
> > but
anybody
> > know
Message 9 of 14
Thanks Neil!
I figured it out!!!
news:10E56724AF4F7EE0E53DDD901EEC3CA6@in.WebX.maYIadrTaRb...
slightly
> different than R6.
> Neil
> > parameters?"
> > Thanks.
should
> great.
Then
> > part
> You
> box,
renamed
> > > HTH
> > > Neil
tutorial.
> file.
> > > but
> anybody
> > > know
Message 10 of 14
But how do I reference part parameters into an assembly. Simple
example, I have a ladder. The rails have a length. Based on this
length, I want to set the number of rungs in a pattern. How do I get
the length of the Rail into the assembly so I can calculate the rung
count?
I don't see a way of deriving into an assembly such that it will see the
exported parameters. Excel is not the correct answer.
I have already solved the problem with VBA but I am wondering if I have
overlooked something obvious.
>HTH
>Neil
>but
>know
Message 11 of 14
Can't say as I have actually done it, and I am sure your ladder example
isn't as complicated as what you are really trying to do, but what if in
your side rails the rung holes were a array, and in the assembly the rungs
were arrayed using the feature pattern?
Personally I think I would just do it as a Master Sketch 8^)
Kent Keller
"Charles Bliss" wrote in message
news:3DF435CC.7030200@cbliss.com...
> count?
Message 12 of 14
The rungs are welded, no holes. I could have an array of points but
that still wouldn't get the number of rungs required at the assembly
level for a pattern.
I presented a simple question so the problem could be understood. It is
more like the quantity of rungs is based on the overall length of the
ladder but with an OSHA minimum and maximum between the rungs.
If you were doing this as a master sketch, how would you control the
amount of rungs without having a part file which contained all the rungs
in one part? The goal is to have one driving dimension for the ladder
height, one for width and end up with an assembly with the correct
amount of steps. The resulting assembly would then be brought into a
weldment and welded together. The resulting BOM would show the correct
quantity of rungs as well.
>Kent Keller
>>count?
Message 13 of 14
There is one way (sorta): I was just reading Kevin Schneider's post on
"Pattern of a Pattern" and tried putting a feature on my "rail" then
patterning the "rungs" on that feature pattern. That worked but still
has a couple of drawbacks. First, it requires me to put features on my
rail that I don't want and second, I couldn't do a feature pattern of
workpoints which would have been my preference (they wouldn't add geometry).
It sure would be nice if Inventor just allowed us to import parameters
into assemblies just like it does from part to part.
> is more like the quantity of rungs is based on the overall length of
> the ladder but with an OSHA minimum and maximum between the rungs.
> rungs in one part? The goal is to have one driving dimension for the
> ladder height, one for width and end up with an assembly with the
> correct amount of steps. The resulting assembly would then be brought
> into a weldment and welded together. The resulting BOM would show the
> correct quantity of rungs as well.
>> rungs
>> Kent Keller
>>> count?
>>> the
Message 14 of 14
I agree completely with your statement below. Doesn't seem like it should be
that hard, and it is a needed tool. Maybe as the Assembly features mature,
they will also add the ability to derive into a assembly. And you are right
about the master sketch, it would end up with one part file containing all
the rungs.
Kent Keller
news:3DF44A81.1040400@cbliss.com...
