No, not possible at this time. Though your particular screen-shot looks
like you're trying to dimension a tube/pipe-run. If you're sweep was
created with a 3D sketch, you can recover that 3D sketch in the iso view and
dimension to those sketch lines.
Hope that helps,
Andrew Faix
Product Designer
Autodesk Inventor
wrote in message news:5572218@discussion.autodesk.com...
Is there a way with the new isometric dimensioning feature to dimension to a
centerline. I have tried to dimension to both a centerline bicector and to
a work axis.
Inventor 2008
