Inventor General
Message 1 of 3 (140 Views)
Dimension spacing when using "Automatic Dimension" in sketch mode
140 Views, 2 Replies
08-07-2009 09:28 AM
Is there any way to automaticly space dimesions when using this command? I use this thing a lot and i end up getting what you see in the attached pic (granted this is extreme given the text boxes). Then i have to individually pick each dim and drag to where i want it.
thanks for any help,
Mike
*Dennis Jeffrey
Message 2 of 3 (140 Views)
Re: Dimension spacing when using "Automatic Dimension" in sketch mode
08-07-2009 01:02 PM in reply to: mikew
Automatic Dimensioning does dimension the sketch, but most oftern does not
preserve any design intent. I never use it except to locate a missing
dimension of constraint quickly. I then Undo and place the dimension
manually.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
http://teknigroup.com
*Expert Elite*
Message 3 of 3 (140 Views)
08-07-2009 01:08 PM in reply to: mikew
Never use it. From what I can see you should investigate Feature Patterns rather than sketch patterns, or break up your sketches in to multiple sketches.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
