Inventor Forum
Dimension in drawing not accurate
9 REPLIES 9
Message 1 of 10
Karol-Or
1307 Views, 9 Replies
The diametric dimension on the right, dia. 244.9 isn't resembling the real dimension in the weldment.
You see in the sketch of extrusion 2 that i gave an internal diameter of 245.
9 REPLIES 9
Message 2 of 10
blair
in reply to: Karol-Or
Unable to open your assembly and drawing file but I suspect you have set your dimension styles to 0 decimal places for you drawing.
Delta Tau Chi ΔΤΧ
Message 3 of 10
Karol-Or
in reply to: blair
no, i didn't set the accuracy in the drawing to 0 decimal places, it is for 1 place.
Some other dimensions in this drawing also became a bit smaller, at about 0.1, like this one.
It seems the part, in the drawing, is shrinked a little in the Y direction.
Also the hatch in the section view is incomplete, it doesn't reach the boundary at a place.
Message 4 of 10
blair
Do a Pack-and-Go to get all the files. Open Windows Explorer and locate the IDW, RMB on the IDW and select the Pack-and-Go to collect all the files and zip them.
Delta Tau Chi ΔΤΧ
Message 5 of 10
Karol-Or
in reply to: blair
I made pack and go
Message 6 of 10
blair
Your "Primary Unit" was set to 0 decimal places. The Tolerance was set to multi decimal places.Capture.JPG
Delta Tau Chi ΔΤΧ
Message 7 of 10
JDMather
in reply to: blair
Blair - did you check the Sketch2 dimension (I forget whether it was in Prep or Machining) in the Weldment.
Message 8 of 10
Karol-Or
in reply to: JDMather
Not the accuracy is the problem, i entered a round 250 diameter dimension in the model, and you can see it if you open the sketch in the part.
All the diametric dimensions in this drawing are shrinked a bit, but not the horizontal dimensions
Message 9 of 10
jtylerbc
Are you sure that your section line on the drawing is passing directly through the center?  If not, that could cause the diameters to appear slightly smaller (since you're not cutting at the full diameter), while not affecting the linear dimensions.
Message 10 of 10
JDMather
in reply to: jtylerbc
Good catch!
These two holes do not share the same center line.
The cutting plane is 5mm left of the center.
