Inventor General
Distinguished Contributor
Karol-Or
Message 1 of 10 (407 Views)
Dimension in drawing not accurate
407 Views, 9 Replies
11-03-2013 03:44 AM
The diametric dimension on the right, dia. 244.9 isn't resembling the real dimension in the weldment.
You see in the sketch of extrusion 2 that i gave an internal diameter of 245.
blair
Message 2 of 10 (383 Views)
Re: Dimension in drawing not accurate
11-03-2013 07:55 AM in reply to: Karol-Or
Unable to open your assembly and drawing file but I suspect you have set your dimension styles to 0 decimal places for you drawing.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Karol-Or
Message 3 of 10 (366 Views)
11-03-2013 10:51 AM in reply to: blair
no, i didn't set the accuracy in the drawing to 0 decimal places, it is for 1 place.
Some other dimensions in this drawing also became a bit smaller, at about 0.1, like this one.
It seems the part, in the drawing, is shrinked a little in the Y direction.
Also the hatch in the section view is incomplete, it doesn't reach the boundary at a place.
blair
Message 4 of 10 (352 Views)
11-03-2013 03:05 PM in reply to: Karol-Or
Do a Pack-and-Go to get all the files. Open Windows Explorer and locate the IDW, RMB on the IDW and select the Pack-and-Go to collect all the files and zip them.
Win7-64
Karol-Or
Message 5 of 10 (339 Views)
11-03-2013 10:47 PM in reply to: blair
blair
Message 6 of 10 (334 Views)
11-03-2013 10:58 PM in reply to: Karol-Or
Your "Primary Unit" was set to 0 decimal places. The Tolerance was set to multi decimal places.Capture.JPG
Win7-64
Message 7 of 10 (319 Views)
11-04-2013 02:26 AM in reply to: blair
Blair - did you check the Sketch2 dimension (I forget whether it was in Prep or Machining) in the Weldment.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Karol-Or
Message 8 of 10 (300 Views)
11-04-2013 05:29 AM in reply to: JDMather
Not the accuracy is the problem, i entered a round 250 diameter dimension in the model, and you can see it if you open the sketch in the part.
All the diametric dimensions in this drawing are shrinked a bit, but not the horizontal dimensions
jtylerbc
Message 9 of 10 (289 Views)
11-04-2013 06:09 AM in reply to: Karol-Or
Are you sure that your section line on the drawing is passing directly through the center?  If not, that could cause the diameters to appear slightly smaller (since you're not cutting at the full diameter), while not affecting the linear dimensions.
John Tyler
Inventor 2013
Windows 7 64 Bit
Message 10 of 10 (272 Views)
11-04-2013 07:33 AM in reply to: jtylerbc
Good catch!
These two holes do not share the same center line.
The cutting plane is 5mm left of the center.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
