Inventor General
Distinguished Contributor
Message 1 of 11 (135 Views)
Dimension a spiraled coil
135 Views, 10 Replies
12-30-2005 09:40 AM
I created a simple spiraled coil IV10, and in my IDW I can't place a center mark in the center of the spiral. How do you dimensiom this? I also want to dimension ID and I can't. Something that you would think is so simple is holding me up.
Please advise
thanks
*Patrick Berry
Message 2 of 11 (135 Views)
Re: Dimension a spiraled coil
12-30-2005 10:18 AM in reply to: koehler
I'm not having trouble on this end. Could you post the model? What kind of
end conditions does the coil have?
Worst case, you can place a work axis in the model and project it into the
view on the idw then use sketch to draw in a phantom circle for the ID.
Patrick
Message 3 of 11 (135 Views)
12-30-2005 10:38 AM in reply to: koehler
Here is the file Patrick. See if you can add a center mark, or an inside dimension.
*Patrick Berry
Message 4 of 11 (135 Views)
12-30-2005 11:07 AM in reply to: koehler
I misunderstood what type of coil you were trying to make. I was thinking
of a coiled spring.
The center mark is fairly easy if you place a work axis in the model and
project it into the idw view. The ID is more difficult since it doesn't
actually exist. I just used a sketch and drew in a circle with a phantom
line at approximate location. Is this what you where looking for?
Patrick
Message 5 of 11 (135 Views)
12-30-2005 11:22 AM in reply to: koehler
Yes that is exactly what I needed to do. I guess the ID has to fudged a bit but that'll work. How did you project the work axis into the IDW view? I already have it in the model. I'll need to learn how to do that since I create quite a few coils of different shapes...
*Patrick Berry
Message 6 of 11 (135 Views)
01-03-2006 08:14 AM in reply to: koehler
Right click on the view and click "edit view". On the second tab (options)
check the box that says "project work geometry". You can then go into the
browser tree and turn the visibility on/off of any work features in the
part.
Patrick
Message 7 of 11 (135 Views)
01-03-2006 10:25 AM in reply to: koehler
OK thanks a lot.
Message 8 of 11 (135 Views)
06-21-2006 12:17 PM in reply to: koehler
What apparently IV cannot do, is project in a sketch the centerlines obtained from the work planes existing in the solid model. Consequently, the phantom circles you are using to limit the ID and OD cannot be anchored to anything meaningful. Am I missing something?
Active Contributor
Message 9 of 11 (97 Views)
03-16-2012 04:44 AM in reply to: *Patrick Berry
I am using Inventor 2011.  I need to add a center mark to a drawing view (without a circle) to locate a point, and I saw your post.  How did you project the axis??  I can't find the option that you mentioned in your post.
Dan
www.yf.com
www.tactair.com
Valued Mentor
japike
Message 10 of 11 (89 Views)
03-16-2012 05:27 AM in reply to: dwing
Add the work features to your model. In your drawing expand the view in the browser by clicking of the plus sign for the view you want to add the centerline to until your model is exposed. Right click on your model and select "Include Work Features....".
Peace,
Jeff
Inventor 2013
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
