Inventor Forum
Dimension Style Default
5 REPLIES 5
BCrosby
9320 Views, 5 Replies
I have created a variety of dimension styles in IV12. Is there a way to change one of the styles that I created to the default style?
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
5 REPLIES 5
Dennis_Jeffrey
in reply to: BCrosby
Make it the active style in your template.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
SBix26
The active Object Defaults style determines the default dimension styles for each different type of dimesion (linear, radius, diameter, ordinate, etc.)
BCrosby
in reply to: SBix26
Sam,
I changed things in the styles manager so that when I use a particular type of dimension (Baselin, Ordinate, Chain, etc.) I now get the dimension style that I desire. What I can't seem to find is what controls the dimension style that is activated when you just use the general dimension button. I still get the "by standard" inventor default. I would like to have this button activate one of my dimension styles.
Bruce
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
jtylerbc
Sounds like you were on the right track in the Style & Standard editor, you just didn't change enough.
Check your Object Default settings for the following:
Angle Dimensions
Linear Dimensions
Diameter Dimensions
Radial Dimensions
These are the ones that are created by the General Dimension command, so changing them to your desired default style should get you what you want.
eliza.dawson
Go into Application Options under the Tools Tab.
Open the drawing tab.
Under Default Object Style, change from "by standard" to "last used"
this should make it so that you don't have to re-select the style you want to use each time.
Hope this helps!
Eliza
