Inventor Forum
Difference between Symmetric constraint and "mirror"
3 REPLIES 3
1509 Views, 3 Replies
I have ran across this from time to time. Here is the scenerio. Say that I
have two points/circles with line dividing the two. I then chose to add the
symmetric constraint, but get an error "adding this constraint will
overconstrain the sketch". I don't understand why I get this. The two
points/circles have no other constraints on them.
The only way that I can get the two holes to be symmetric about the line is
to delete one of the holes and then do a mirror about the line.
Any ideas on why Inv. works this way? I am sure that it is something that I
am overlooking, but it seems that if there are not any constraints on the
points, adding the symmetric constraint should work.
Inventor 5.3 sp2 / V6.0 sp....
Win XP Pro
P4, 2 Ghz, 512M
Gloria II-64
nVidia v6.13.10.4041
1280x1024, 32 Bit
3 REPLIES 3
Are the circles dimmed, maybe? Mine works okay.
~Larry
"Kirk A." wrote in message
news:E9054786F3ACE44A67456F9C70DE17D3@in.WebX.maYIadrTaRb...
I
the
is
I
> Win XP Pro
> P4, 2 Ghz, 512M
> Gloria II-64
> 1280x1024, 32 Bit
I just tried it, with no problems. Do you have dimensions on both holes?
Maybe, you can post your file to CF.
Mike
I
the
is
I
> Win XP Pro
> P4, 2 Ghz, 512M
> Gloria II-64
> 1280x1024, 32 Bit
I've had similar issues with the symmetry constraint. I was trying to center squares on reference lines though. I ended up having to use construction geometry in lieu of the symmetry constraint. I'm also using IV5.3sp2.
-Matt
