Inventor General
New Member
sartorimartin
Message 1 of 2 (132 Views)
Accepted Solution
Diferences in measurements between partlist and drawing
132 Views, 1 Replies
07-19-2012 06:29 AM
To all,
I've done a 3D frame in Inventor 2012 and after doing a 2D with a partlist chart I found differences between lengths. The length of the part list was the first one, the frame was modified and the partlist didnt update.
Found out that the d18 parameter was a fixed number. I managed to change it manually by changing the G_L parameter to d18 (Using PNU, image attached).
How can I set up my inventor to update the part length automatically?
Something with the family properties maybe?
Thanks for your help.
Martin.
New Member
sartorimartin
Message 2 of 2 (118 Views)
Re: Diferences in measurements between partlist and drawing
07-19-2012 10:57 AM in reply to: sartorimartin
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
