Hello everyone,
I have a model of a Rack that I have configures with iAssembly (2 configurations with different amounts of equipment on them). I have setup 2 level of details to reflect this.
But when I go to the 2D drawings I cannot select either of these Level of Details in the Drawings.
Is there a way to show these level of details? Or should I do this another way?
Thank you in advance.
Solved by jozef.dubaj. Go to Solution.
Hello Ashley,
seems your iassembly file need saveing before use in the drawing. Notice the "LevelofDetail1" in the Drawing View dialog. This is default naming for new LOD created. Seems this was the last time when assembly was saved. Try to save the assembly and place it to new (blank) drawing. Both custom views should be loaded in the list.
Let me know then.
Jozef
