In a detail view, how can I change the line type? The contour of the detail view?
Sophie
Solved by yannick3. Go to Solution.
Here is an example.
In this atachment I have got a "double dach chaine" line.
And in some old drawings I get a "continuous" line.
How do I change that?
Sophie
Hi
Do you want pnly change the line style for one drawing or librairie style
try this, RMB on detail view, Edit view annotation style and on the next window all paratmeter will appears
save and exit. and now if you want to save in the librairie, go to manage tab, styles and standards, save
I know i can change the style... but I just can't change the line type of the Detal View! (like in my last atachment)
Do you know where exactly?
Sophie
Hi
go to style editor, add new layer with the line style and color that you want, after go to object default,
select your standard default, detail view callout, and change the layer with the new one after, save your style in the librairie
